Old 12-12-2005, 10:55 PM   #1 (permalink)
Default compatibility issues
Will there be compatibility issues in running a 32 bit application on a 32 bit OS (say Win XP ) which has been installed on a 64 bit processor. Please guide me about the possible solutions and also the propable applications which are likely to create problems
hariharan is offline
Old 12-12-2005, 11:15 PM   #2 (permalink)
On an AMD?? It's compatible with 32 bit apps. Dunno abt Solaris n co.
Anway the way I see it, if the OS supports it the app, the it supports it. Period.
LordDJ is offline
Old 12-12-2005, 11:56 PM   #3 (permalink)
yes I'm speaking about AMD Athlon 64 3200+ and the RS 480M2 combination
Old 13-12-2005, 08:55 AM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
It will work just fine! Dont worry!
kalpik is online now
Old 13-12-2005, 01:32 PM   #5 (permalink)
yeah if d OS works den even the app should
ishaan is offline
- by gohan89
