Old 12-12-2005, 09:18 PM   #1 (permalink)
"Technologic"
Apollo's Avatar
Default DOS on Startup
Hi, got a question...
Want to make my PC start in the DOS mode, during bootup, and not allow the Windows OS to load. (Getting a similar interface as we get on doing Run > command from the 'Run' option from the Start button)
Don't want to use any windows startup disk in order to do this.
Is it possible?
One great use of words is to hide our thoughts.
Apollo is offline
Old 12-12-2005, 09:25 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
F8 > Boot into Safe Mode with Command Prompt ?
which windows ? 98,me,2000 or XP ?
If old windows > Start > Shutdown > Restart in DOS mode !
Harsh J
www.harshj.com
QwertyManiac is offline
Old 13-12-2005, 07:31 AM   #3 (permalink)
its not what he meant i think... i hav seen ppl doing this but dont remember how,.... coz it was way back during windows 95 os. the comp gets started in DOS and we type "win" and enter to get into windows mode...with a google search, i got this... hope this helps.
Originally Posted by legolas
Click Start/Run, type MSCONFIG in the 'Open' box and press enter. When the
'System Configuration Utility' opens, click the 'Advanced' button. Now check
the 'Enable Startup Menu' box selection and then click 'OK'. When the 'Advanced'
window closes, click 'Apply' then 'OK' and reboot when prompted.
this is for windows 95/98. i dont think u can start dos in win xp at boot.
/legolas
legolas is offline
Old 13-12-2005, 09:25 AM   #4 (permalink)
Not sure but I think that if you make a partition and install DOS in it, you will get started in DOS automatically... To restore Windows booting regularly, boot with the Windows boot cd and run fixmbr...
Arun
sakumar79 is offline
Old 13-12-2005, 11:30 AM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
can u run norton antivirus FULL HDD scan through DOS ???
... W H O T ...
ax3 is offline
Old 13-12-2005, 12:14 PM   #6 (permalink)
Not sure about Norton AV, but you can use F-Prot Antivirus for DOS which is free for home use... Details at http://www.f-prot.com/products/home_use/dos/
Arun
- by gohan89
