Is it possible to use the hard disk as a pen drive?That is I should be able to connect the hard disk to USB and use it the same way as a pen drive so that I don't have to open the cabinet and connect the hard disk as a slave.
If you have any idea of doing it ,plz share it with me.
In just two days, tomorrow will be yesterday.
Yes its possible , you have to buy these USB HDD case. The HDD fits inside the case and the case has a wire connecting it to the USB port. This is how you can make an internal drive to function as an external HDD/ pendrive.
The overall size is just as big as an external modem.
what is the cost of that? and is it worthy? i mean efficiency wise... and any specific brand recommendations?
How much does a casing and cable stuff costs....also tell me some good company of which I should buy....
I have bought a 120 GB LST SEAGATE Internal Harddisk for 4500/- have i bought it for a right price...its a new piece and one year warranty....
Yup
i also have use it.
It costs abt 700 to 1000 much.
but u get 40,80GB as USB.
i suggest to buy new LAPTOP HDD with USB casing.
It costs u abt 3 to 5k (40GB)...may be varying..
but laptop hdd is small. so u can keep it in ur shirt pocket also like pendrive,like a calculator.
But i have already bought it...I don't think so Laptop HDz cost so less..they bit expensive and moreover I don't want to carry it any where the only reason why I want to convert it to external one is because I can't get it fixed inside my laptop...i bought this by mistake through bidding....so for 120Gb seagate HD i should buy 3.5" cabinet right...
