Originally Posted by con_tester
Q7.) Why cant I see some of the picture posted in thread of this site.
I can see some of them but not all in Opera or in any browser.
I m using zone alarm. Is this creating problem.
I am not answeing your other qs as a few membershave already answered them.
Yes even I was facing this problem.
Zone alarm add blocker causes this problem. This is a part of the FW itself.
Use the following steps to undo that.
Method I
Open ZA.
Click Privacy
In the center of the screen on the right side click custom and then click the AD tab . Remove all the check marks in
ads to block box or mess with the settings if you want to block certain adds and not all adds.
Method II
What I have done is I have enabled AD blocking by selecting the 1st and 2nd check mark in the
Ads to block box
But in the
Ad Void Control box I selected the 3rd option which allows me to click and see the ad or picture whatever has been blocked.
This is a better choice and it avoids advertisements also.
Choose whichever method you like.
If its confusing please tell me and I will send a screenshot.
Regards
