Oh, thats in WMV form and opens in a Javascripted window.. so bad luck i think... beter record the screen motion... or look in the temp folder for some traces of WMV...
Yes exactly you have to directly record while it is playing online.
------------------------------------------------ Method I - USe this if you have many tracks to record or if you lack patience.
To record you can use a software like JetAudio and then selecting the source "Stereo Mix".
------------------------------------------------- Method II - Use this if the nos of tracks to record are few and you have ample patience.
If your not doing a professional recording and are just doing a recording of one contestant then you can use the Windows recorder to record. To enble "Stereo Mix " you have to click on the "speaker " in the tray next to the time ->> then click options->>Properties
After that a box will open .
In that box select recording make sure that you check mark the Stereo Mix ->> click Ok
Once thats done another box opens. select the chk mark under stereo mix. Keep the slider as low as possible or else the music shatters during playback.
Generally 2 tabs from the bottom are enough.
Remember when using Windows recorder you have to be quick at clicking the record button every 60 seconds or else there will be gaps and the continuity of the songs will be lost. It took me some time before I could master this, but now I can do so and thats why I said you require patience.
Both the methods are equally good , choice is yours
I have not yet seen the site but you can rip off the wmv using the source code.
प्रासादशिखरेऽपि सन्न काको गरुडायते ॥
No matter how high a fool may rise, he remains a fool -RigVeda
