Old 12-12-2005, 07:05 AM   #1 (permalink)
Core of the Processor
Default ram problem
Hi. i m a regular reader of ur magazine. my problem is about ram.i want to buy a ram from my vendor.i m keen to buy a simtronics ram but my vendor told that all ram are same ,so he is interested in Perx ram. please help me . is it ok for perx or not.....
jmit is offline
Old 12-12-2005, 09:03 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
You can buy any company's RAM, all RAMs are the same, jus make sure that you buy the right frequency suitable for your Motherboard and make sure it comes with a warranty so that you can replace it if it goes bad due to some unfortunate events
Harsh J
www.harshj.com
QwertyManiac is offline
Old 12-12-2005, 10:04 PM   #3 (permalink)
::cyborg::'s Avatar
i recommend that u buy kingston it is well expensive a bit to simmtronics but its performance is damn good excellent and make sure to consult ur mobo manual before buying so as to make sure u dont buy the wrong speed ram
::cyborg:: is offline
Old 12-12-2005, 10:17 PM   #4 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
all RAMS are the same
but HYNIX is the most cost effective one in the branded category
vijay_7287 is offline
Old 11-03-2007, 09:07 AM   #5 (permalink)
~ Harsh ~
hdsk.23's Avatar
Default Re: ram problem
hey jmit check this out my post useful for u
Perx RAM
hdsk.23 is offline
- by gohan89
