if u can download it, download
WinLinux. (its 363 MB)
they say it can be installed on a system with win 9x on fat32.
WinLinux 2003 Unique Features
WinLinux 2003 was designed and built to be the easiest to use Linux system. Its installation and configuration tasks are performed directly from Windows and with graphical tools Windows users are used to. Below there is a list of its unique features:
* Windows integration: WinLinux 2003 installs as easily as any Windows application
* Smart configuration: your hardware devices are detected and automatically configured to reflect your current settings and preferences**
* Easy start: you can start WinLinux 2003 just as you start any other Windows application, just double click it
* Safe installation: you do not have to put your existing data at risk to install it as you have to do with other Linux systems (no HD repartitioning)
* Easy troubleshooting: a Troubleshooting Utility is included to simplify the request of Online Support
* Optimal Disk Usage: WinLinux 2003 shares free disk space with Windows, i.e., you do not have to set two independent hard disk partitions that do not share free disk space.
* Familiar look and feel: you will be amazed by how simple it is to use KDE, the graphical interface used by WinLinux 2003. Take a look at some screenshots and see you will be in a familiar place.
Linux Features
* Linux is virtually immune to all DOS/Windows viruses.*
* Linux is very stable and rarely crashes. It is used by thousands of companies around the world in 24-hours systems.
* Linux is based on open industry standards so you are not obligated to buy everything from the same company.
* Linux has a handful of applications, utilities and games already developed for it. Most big software developers already support Linux and more are joining in.
* You can even download Linux office applications for personal use for free.
System Requirements
Your computer must have, at least the following configuration to run WinLinux 2003.
* a Pentium II class processor
* 64 MB RAM
* VGA video card
* Windows 95, Windows 98 or Windows Millennium. Note that Windows NT, Windows 2000 and Windows XP are not supported by WinLinux 2003 yet.
* an disk drive with approximately 1.2GB free space on a FAT32 system or near 2GB free space on a FAT16 system (most Windows 95), for a full setup.
To enjoy WinLinux in full, we recommend also the following:
* a modem and an Internet connection
* 128 MB RAM
* SVGA video card
* a sound card
* free HD space to install third party applications
