Old 11-12-2005, 03:04 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Default save addl disk space thus ...............
heres how u can save additional disk space,
using "remove hotfix backups v 2.1.6" 8)
when u install Windows Update, backup folders r created for the files that were replaced during the update. These are created so that you can easily uninstall a particular Hotfix, if it causes problems with your system. If your system is running stable and you don't need to uninstall the hotfixes, then you can safely remove the backup files to free up disk space. u can alway manually delete the $uninstallxxxxx folders and the addremove/ registry entries; or u can use 'remove hotfix backups utility v 2.1.6' which does a smart job at it !
This small freeware utility will locate the Hotfixes that have created backup files on your system, and will remove those backups. It will also removes the associated Registry entries for these items in Add/Remove Programs.
click http://www.dougknox.com/xp/utils/xp_hotfix_backup.htm
the site http://www.dougknox.com/index.html also offers an excellant
range of tips, trick, utilitys, and fixes for winxp. check it out
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 13-12-2005, 01:33 PM   #2 (permalink)
MVP in VC++
Thanx for the info dude...
cvvikram is offline
- by gohan89
