The Config -
MoBo - Asus A8N SLI Deluxe - 939 Soccket.
BIOS - Asus A8N SLI Deluxe ACPI BIOS Revision 1006 - Release - 03/03/05
800 Mhz - FSB.
AMD Athlon 64 - 3200+ - 939 Pin.
512 * 2 DDR RAM - Dual Channel Hynix - 400 Mhz.
160 GB - Seagate SATA HDD.
Win XP with SP2.
I have these monitoring software installed on my PC - these software came with the MoBo
Asus Probe 2
Asus AI Booster
The Problem -
I got a warning on ASUS Probe saying that the chipset fan speed is below minimum threshold.
I also heard creaking sounds in the CPU.
Then, After a few minutes, the fan was at 10,000 RPMs.
And the noise was gone.
When I checked - both the softwares were showing the same fan speed.
When I booted up the next day I got this Message -
"Warning - ChipSet Fan has stopped or is too slow.
Press F1 to Continue"
How do I solve this?
Plz Help
ThanX in Adv.
