Old 11-12-2005, 12:20 AM   #1 (permalink)
Default DVD Problem!!!!!!!!!!!!!
I recently bought a 5 in 1 Star Wars DVD Collection. However in one one movie, there is a constant audio commentry although the movie's sounds can be heard dimly.I turned the audio commentry off from the movie's menu but the commentry continues.I tried copying the particular movie to the HDD but the commentry still continues.Is there any way to solve the problem?
rachit27 is offline
Old 11-12-2005, 01:43 AM   #2 (permalink)
Try Using different DVD playing software, if problem persist try DVD'd on Home dvd player.
I think its only a software problem.
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 11-12-2005, 01:44 AM   #3 (permalink)
ya u can directly change the audio track in use...different methods in different softwares, but usually just right click on the screen and look for audio options
there, select ENGLISH most prob it will be the first one, but u can try all the tracks one by one till u get it rite
im assuming ur trying in a computer
even wen u copy 2 ur HDD...in the dvd ripping software choose a different audio track until u get it right
also, check on the dvd...maybe they made it wid commentary only for sum special reason and they dont have a non commentary version on that dvd
and finally, if its pirated, the guy who copied it must hav selected the wrong track while burning it so he burnt the audio track with the commentary by msitake...then u cant do anything about it
ishaan is offline
Old 11-12-2005, 10:52 AM   #4 (permalink)
try powerdvd i experienced no problem wit that. you can change settings in that to correct your problem
calvin is offline
Old 14-12-2005, 03:42 PM   #5 (permalink)
I use PowerDVD and it is the software on which the problem arises.
rachit27 is offline
Old 14-12-2005, 05:18 PM   #6 (permalink)
did u try wat i rote? did it work?
ishaan is offline
Old 15-12-2005, 09:59 PM   #7 (permalink)
Yes I tried but it didn't work.
rachit27 is offline
Old 03-01-2006, 09:17 PM   #8 (permalink)
Hey!somebody please help me!!!!!!!!!!!
rachit27 is offline
Old 03-01-2006, 09:35 PM   #9 (permalink)
dIgItaL_BrAt's Avatar
Try using DVD Shrink and select the required audio stream.
dIgItaL_BrAt is offline
Old 03-01-2006, 10:15 PM   #10 (permalink)
::cyborg::'s Avatar
i think u should use the latest dvd software for playing like the cyberlink suite try it it might help
::cyborg:: is offline
Old 03-01-2006, 10:20 PM   #11 (permalink)
dude i dont think he quadruple posted on purpose he must have not realised cuz of connection probs or something...cuz look at the post times theyre just minutes apart
ishaan is offline
- by gohan89
