Old 10-12-2005, 10:56 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default PIII 866 MHz. works like a 486 machine. Please help???
Hello friends!
I have a computer with a PIII 866 MHz. processor, 128 MB SDRAM, 20 GB Segate HDD, VIA VT8601T motherboard and Windows 98SE as the OS. The problem is that since the last few days my computer has become very very slow. My first thought was that a virus can be a reason and therefore I deleted all partitions, created two new partition with 4 GB and 16 GB respectively. After formatting it with FAT32, I reinstalled Windows 98SE, but still no gain. The system seems to work like a 486 machine and hangs everytime I try to open two or three application at a time. Bare Windows 98SE without any other softwares installed takes more than 4 to 5 minutes to start and a 20 MB file takes about 2 minutes to be copied to the HDD from a CD.
I just dont understand why the hell is the system working so very slow. This all started after I gave my CPU to a hardware engineer recently to replace my SMPS and I dont know why, but I have a feeling that my HDD has been changed.
Now, what can be the reason behind all this. Is such a kind of problem arise due to faulty HDD or SMPS. If not, what can be the other reasons behind it. Is there any way to solve this problem. As per my view, I see no problem with the software settings as it is the same as they always used to be.
Please help...
Thank you.
go4saket is offline
Old 10-12-2005, 11:05 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
check ur RAM with memcheck
and run scandisk on th HD
looks like HD prob ...
vijay_7287 is offline
Old 10-12-2005, 11:10 PM   #3 (permalink)
9437077259
go4saket's Avatar
RAM doesn't seem to have any problem.
go4saket is offline
Old 10-12-2005, 11:48 PM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Please post your HijackThis Logfile for better assesment of your problem.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
- by gohan89
