Old 10-12-2005, 01:20 PM   #1 (permalink)
vignesh's Avatar
Default Free Backup tool
Is there any backup software like Nortan Ghost ?
vignesh is offline
Old 10-12-2005, 01:31 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
a bit of googling has incresed confusion on ths one ...
abt nortan ghost
http://www.cybertechhelp.com/forums/...hp/t-3628.html
http://groups.yahoo.com/group/jfw-em...t/message/1959
vijay_7287 is offline
Old 10-12-2005, 01:45 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
What are those links supposed to mean to the topic
Not sure if good or not but try its website :
http://www.xxcopy.com
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-12-2005, 01:53 PM   #4 (permalink)
vignesh's Avatar
Thanks mate..
@Vijay Whats your point.I didn`t get it.I know how Norton ghost works..
vignesh is offline
Old 10-12-2005, 01:56 PM   #5 (permalink)
Check out http://www.thefreecountry.com/utilit...andimage.shtml for some free hard disk imaging utilities... Also, some backup utilities are also included....
Do note, imaging and backing up are not the same... Norton Ghost does HD Imaging (take a full snapshot of the hard disk), whereas backing up is a more generic term that is used for creating backup copies of one or more files... If your hard disk crashes, you will need an image of it to restore it quickly, otherwise, you have to restore files from backup and reinstall programs...
Arun
sakumar79 is offline
- by gohan89
