Loopback address is a special IP number (127.0.0.1) that is designated for the software loopback interface of a machine. The loopback interface has no hardware associated with it, and it is not physically connected to a network.The loopback interface allows IT professionals to test IP software without worrying about broken or corrupted drivers or hardware.
127.0.0.1 is a loopback network connection.
This means that if you try to connect to 127.0.0.1, you are immediately looped back to your own machine.
Yeah, must see Wikipedia
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
My advice would be never to use the ping command with loopback IP. It wont' affect the fast comps today, but somehow it may eat up your resources within seconds.
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
Address ping?
are they also loop back addresses? if not why do they ping?
Million's Of Open Minds Can't Be Wrong!
http://nc.xmgfree.com/weblog
Everybody Wants to go to Heaven...But nobody wants to Die! :wink:
