Old 09-12-2005, 06:22 PM   #1 (permalink)
Default hw to remove the copy protections ina CD?
hello,
hw can we remove the copy protections in a CD?
if it cannot be done,hw can we copy CD to CD it it is copy protected?????
help me yaar
dittualex is offline
Old 09-12-2005, 07:19 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
copy protection s/w uses some kinda hidden files to stop ppl frm copin
when we do it cd 2 cd the entire image is transfered so no probs there
not sure exactly wait for others ....
vijay_7287 is offline
Old 09-12-2005, 09:51 PM   #3 (permalink)
enoonmai's Avatar
Please post the reason as to why you want to remove copy-protection from a disc. If its for a legit purpose, you will get help here, not otherwise.
Playing FEAR XP/LSW2
enoonmai is offline
Old 10-12-2005, 11:48 PM   #4 (permalink)
choudang's Avatar
ya, i need a help for it too. i think it will be legal for my case.
i have recorded the marrige cer of my brother and i gave it to editing [i have pinnacle, but don't have the card]. what they do, they locked the cd, and now i can't make the copy of that. i went to them to make some copies and they asking 50 bugs/cd. i have spend already 2500 bugs and i don't want to spend more. i need arround 20 copies for my relatives and bro's in-lawys.
i hope that this is a legal, cuz i give them the making charge and its not fare that they locked the cd to protect their so called effets and pictures.
For every action, there is an equal and opposite criticism.
choudang is offline
Old 11-12-2005, 09:29 AM   #5 (permalink)
@warrior
Since your case is legitimate you can use the software called clone Cd. It will copy the as a image to your harddisk with copy protection. Then you can burn 'n' number of copies from that image.
If you need help pls let me know i will post the screen shots of the software.
Regards....
shivaranjan.b is offline
Old 11-12-2005, 10:01 AM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
U can also use Virtual Daemon 4
Harsh J
www.harshj.com
QwertyManiac is offline
Old 11-12-2005, 10:15 AM   #7 (permalink)
as you say its for a legitimate purpose.
try these steps:
SOLUTION 1: DO IT URSELF
1.)download isobuster from http://www.isobuster.com/
2.)create a folder in your system to store the cd contents
3.)open copy protected cd with isobuster
First, start up IsoBuster and hold down your shift key while inserting your copy-protected CD.
I recommend that you hold down the shift key because it blocks the Windows ‘autorun’ feature, i.e., prevents the CD from launching programs automatically. The reason this is necessary is that some copy-protected CDs (for example Contraband by Velvet Revolver) automatically install suspicious Windows drivers, which people have reported cause problems when you later want to play normal CDs. If you don't want to hold down the shift key every time you insert a copy-protected CD, there is also a way to disable autorun altogether.
4.)extract the cd contents to your folder
5.)burn the folder contents onto blank cd
6.)ENJOY !!
do refer the source for details :
http://www.dsg.cs.tcd.ie/~haahrm/copying-protected-cds/
SOLUTION 2: USING SOFTWARES
1.)use CDMATE 30day trial then buy software .
http://www.cd-mate.com/downloads/CDM_Enu_Latest.exe
OR
2.)use freeware clonyXXL
http://www.cdfreaks.com/software/download/75
SOLUTION 3: SEARCH IN PROPER WEBSITE FOR SOLUTION
HOPE IT WORKS.
haven't tested it myself. never felt the need.
calvin is offline
Old 11-12-2005, 12:07 PM   #8 (permalink)
u can also use dis software called Alcohol 120%
and most burning softwares like Roxio and Nero have this option...Make an Exact Copy...or something which means the same thing....it copies most of the time even if its protected
ishaan is offline
Old 12-12-2005, 06:27 PM   #9 (permalink)
choudang's Avatar
thanks guys.. let me try.
choudang is offline
Old 13-12-2005, 01:15 PM   #10 (permalink)
if u wanna make a copy of a copyright CD then the first step u have to do is make a .iso image backup of that cd Using Nero or the dd command in Linux or u can find many other alternative softwares for doing this job then u need to burn the the .iso image to a cd, all the latest cd burning softwares such as Nero, GraveMan, Gnomebaker, k3b have an option of burning .iso images to cds... i tried making backup copies of my Windows XP cds by directly copying CD to CD but i discovered later that this method didnt work and the backup cds were no more bootable, so that when i made a .iso backup and then burnt and this worked and the backup cds were bootable so try it out this should be able to solve ur problem
fighting for peace is like ****ing for virginity
cryptid is offline
Old 14-12-2005, 02:52 PM   #11 (permalink)
d
is this possible in need for speed most wanted? I've bought the black edition and there's something wrong with my CD Drive...it keeps making noises...n for christ's sake i don't want to damage the disc?i'd be grateful if anybody has a solution with reference to this particular software.....??For your info, It isnt illegal....I have the receipt for the purchase.
The torquemaster rules.
d is offline
Old 14-12-2005, 03:52 PM   #12 (permalink)
dIgItaL_BrAt's Avatar
Yes it is possible for NFS:MW.For game cd's Alcohol 120% or CloneCD would be the best.U could even run the image file directly from the HDD using Daemon Tools.
dIgItaL_BrAt is offline
Old 14-12-2005, 05:21 PM   #13 (permalink)
yeah and after using both of them, i prefer alcohol
i think somebody did a comparison on this forum between dese 2 softwares search for that...or look on google also
ishaan is offline
- by gohan89
