Old 09-12-2005, 05:33 PM   #1 (permalink)
Default Sony DRU-810A or BenQ DW 1640A
Hi all,
Which DVD writer will be better one of the two.....in terns of performance and price?? I would like to buy it from Nehru Place....anyone know about its price and avalibility??
Thanks
jack// ani is offline
Old 09-12-2005, 07:32 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
lite on 1693
cost = Rs 3100
vijay_7287 is offline
Old 09-12-2005, 08:49 PM   #3 (permalink)
Thanks for reply.....but I was asking about the two mentioned in the subject line Sony DRU-810A or BenQ DW 1640A.
Old 09-12-2005, 08:59 PM   #4 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
lite on is the best
but if u r forced to make a choice then i will say
the one frm Benq is the better one
Old 09-12-2005, 09:11 PM   #5 (permalink)
Thanks again....I'm not forced at all. Actually few days ago....there was a discussion about DVD writers, guys were saying Sony and BenQ are the best one. As they support Dual and Double layers as well....so I got confused. BTW....do the Liteon one also have similar capability??
Old 09-12-2005, 09:12 PM   #6 (permalink)
Aniruddh's Avatar
Sony is the best as far as i know and then Benq,hav heard from many bout Benq DVD-RW that its really good.go for either of these 2 they r better then any other brand.
Aniruddh is offline
Old 09-12-2005, 09:14 PM   #7 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
ya maybe Benq is like more available than LiteOn
but it matches it in all aspects
Old 09-12-2005, 09:15 PM   #8 (permalink)
benq, search the forum and u will get many topics in which benq is the clear winner
Shwetanshu Srivastava
shwetanshu is offline
Old 09-12-2005, 11:32 PM   #9 (permalink)
Benq all the way. It is the best performing DVD burner out there at the moment. Sony comes in next.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 10-12-2005, 09:45 AM   #10 (permalink)
Thanks for all your nice suggestions.....so what is the current price of BenQ writer in Delhi.
Old 10-12-2005, 10:40 AM   #11 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
i think it comes for abt 2.6k
Old 10-12-2005, 11:52 AM   #12 (permalink)
@jack//ani
well you might want to take a look at the website
http://www.cdfreaks.com which does a extensive review of the optical storage devices.
Well as per the site benq dw 1640 is given the top most rank while sony 810u has been given a good review too.
so the next thing is the price. so go the cheaper of the two
Life is a gift , dont waste it on computers.
..............waste it inside it.
ranju_neel is offline
Old 10-12-2005, 12:28 PM   #13 (permalink)
Go for the Sony !!!! It supports dual layer and double-sided also.
There is a very fine line between genius and insanity. I have erased this line.
freezer is offline
Old 10-12-2005, 01:25 PM   #14 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
so does Benq !!!
Old 11-12-2005, 12:04 AM   #15 (permalink)
BenQ, I m Using it and it gives splendid performence.
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 07-01-2006, 10:39 AM   #16 (permalink)
Default reply
I completely agree With Aniruddh. Both Are The Best. Either of them Will do. I bought For myself Most Recent SONY DW Q30A for 2700 in mumbai.
Although i went to buy it with the mindset that" Whichever is cheaper on that day, i will go for it. Sony was for 2700 and benq was for 2800.
So Sony Won it for me
Andyiz is offline
- by gohan89
