15-10-2004, 05:03 PM
We Both Have a Mouse!!!
SATA YA PATA
i recently bought a new pc (assembled) athlon 64 3000+ with msi k8mm-ilsr mobo and samsung 80 gb sata hdd, it worked fine for 4 dayes and after that it started hanging frequintly (when ever i watched t.v. programs usng my internal tv tuner card{intex}).
after 2 dayes, my pc refusd to start, i thaught it was the fault of my ram(because my pc didnot accepted 2x256 hynix400fsb ram and i have to use 1x512 matrix400fsb ram), but i later came to know that i is acctually my hdd which is causing trouble(whenever i pluged the hdd to the smps power the pc refused to start, and now all the important data i had collected is lost, i have sent it for replacement and it will take 7 dayes (samsung service center people said).
now finally my question for all you guyes are:-
1. why did it happen(brand new hdd double crossed me).
2. are sata not reliable as pata are.
3. should i replace it and buy 120gb 7200 rpm segate or samsung, OR 80 gb 10000 rpm cheetah(i do not know the price of cheetah).
please help
regards,
nishant.
15-10-2004, 05:59 PM
Go 4 SATA only if u don't have Lots of OverClocking in ur mind b'coz SATA HDDs seems 2 restrict the extent of OC. Go 4 PATA if u keep money in mind and ultimate OC is ur choice. 4get Seagate Cheetah b'coz its SCSI HDD more costly and lot better performance but u require SCSI adapter.
RULER NEVER GETS DEFEATED....WHATEVER THE SITUATIONS BE!!!
15-10-2004, 08:15 PM
thats not true, SATA doesn't restrict overclocking
Cheetah isn't recomended for home, it's really costly
get a PATA, before 2nd generation SATA the 1st generation is not good over PATA, all a bit costly
15-10-2004, 10:42 PM
1) sheer bad luck dude nuthin u can do abt it
2) thers nuthin like its not reliable .. either u were given faulty hardware or u just had real bad luck
3) dont go for 120 ... go for 160 instead
its something abt the number of platters they use
10000 rpm cheetah is too much i think .. but go for it if u can afford it
itll give amazin performance
No Mercy, No Limits.
15-10-2004, 11:23 PM
SATA is the thing to go in for. PATA is 50% slower (100Mbps Vs 150Mbps) data transfer rate . DO NOT BUY SAMSUNG HDD. Try to get seagate now it is with a 5 year warranty
**** happens
16-10-2004, 06:05 AM
who says SATA restricts overclocking ..? any link or something to prove it!
16-10-2004, 06:50 AM
SATA Hdds didn't obstruct overclocks untill the PCI locks of chipstes are extended 2 it. if not its certain 2 restrict OC. same is tru with IDE HDDs. don't worry almost all modern chipsets hav this feature except Via K8t800. Ide HDDs of 10K Rpm r really cheap and give performance almost equal 2 SATA hdds havin 7200rpm. 10K rpm SATA hdds r really costly. moreover the bandwith of 150Mb/s is jst theoritical and current PATA drives wud giv u a theoritical bandwith of 133Mb/s
Q : What\'s Flash ?
A : The fastest thing in the world.
Q : Who am I ?
A : The Quickest [flAsh]
16-10-2004, 08:23 AM
ok if sata gives 133Mbps then PATA gives 80Mbps of throughput data so sata is better in any case also sata help the system run cool due to the sexy data cable it uses
**** happens
16-10-2004, 08:50 AM
www.Oobertech.net
16-10-2004, 11:38 AM
thanks all u guyes for your help,
i bought samsung hdd in the first place because the 3 year warrenty is given directly through service center and replacement is faster, i know seagate hdd's are little better and have 5 years warrenty but the warrenty is covered by dealer and it takes 1 month for its replacement(if any prob comes, like i have).
so guyes i am thinking to keep my current hdd,
any suggestions please.
regards
nishant.
C2D E6750@3.6GHz - XFX 650i Ultra - XFX 8600GT - 2x1 2GB 800MHz JetRam - CoolerMaster eXtreme Power Duo 600W - 750GB HDD - LiteOn LightScribe DVD RW -
HP W1907 19" Wide...
and Altec Lansing ATP3...
16-10-2004, 04:15 PM
I can say that from personal experience.
Since when did 10,000 rpm IDE drives become available in the market,when such drives were never made? :roll:
SATA drives are experiencing these problems because of the low quality SMPS too.
If possible go for a SMPS that comes with SATA connectors or choose a Good quality SMPS which supplies healthy power and can sustain teh power requirement of SATA Drives.
16-10-2004, 06:17 PM
The first generation of SATA 150 over PATA 133 is no go, won't give any more performance
The 2nd generation however supports NCQ (Native Command Quing) but suported only in 915 chipsets & upcoming nForce4 chipset
SATA doesn't restrict overclocking if U R not using it on a motherboard without official SATA support, on 865/875/9xx SATA doesn't restrict over clocking
Also Windows XP requirs drivers for SATA while installing Windows, that "Press F6 to install a Third Party drivers" thing, but it can be solved with a slipstreamed CD
Whats worng with Samsung, it's working fine where ever I have seen it
16-10-2004, 07:54 PM
Nvidia Nforce 250Gb has native SATA support and overclocking is limited on board based on these chipsets for socket 754.
Any reason why? :roll:
16-10-2004, 11:07 PM
yes 10K rpm SATA disk are available check out maxtor
**** happens
16-10-2004, 11:39 PM
10k sata drives is ok but this guy is talking about 10k IDE drives which is unheard of. :roll:
17-10-2004, 10:59 AM
i am getting an option from a local wendor
he is saying that give me your samsung 80gb sata hdd(replaced one) and pay additional R.s.200 and take seagate 80gb sata hdd.
so guyes what should i do keep my current hdd or exchange it????
17-10-2004, 11:51 AM
Looks fishy ........!!!!!!!!
18-10-2004, 11:39 PM
hey darky, it seems u didn't heard bout IBM Delta 75GXP, a 75GB hdd which had 10K rpm & arrived in India in the year 2000(or 2001). U can check previous Digit(CHIP that time) issues if u hav them.
Q : What\'s Flash ?
Q : Who am I ?
19-10-2004, 03:31 PM
#19 (permalink)
Originally Posted by [flAsh
]hey darky, it seems u didn't heard bout IBM Delta 75GXP, a 75GB hdd which had 10K rpm & arrived in India in the year 2000(or 2001). U can check previous Digit(CHIP that time) issues if u hav them.
No my dear the first ATA drive wid 10k rpm was the WD Raptor.which is a SATA drive essentially.
IBM 75GXP was a 7200rpm drive, had 4 platters, had tremendous failure rate and was very infamous for its failure.
10k & 15k SCSI drives is common.
There is NO IDE 10k rpm DRIVE till date.
Check on your side, mate.
20-10-2004, 11:12 AM
#20 (permalink)
may b !!! I saw bout 75GXP in chip only telling it 2 b a 10k rpm ide drive with 4 mb cache
Q : What\'s Flash ?
Q : Who am I ?
Search this Thread |
