Old 09-12-2005, 12:14 PM   #1 (permalink)
Default Why it shows 152 GB instead of 160 GB?
Though I bought a HDD with 160 GB capacity it shows only 152 GB. What could have happened to the remaining 8 GB? It shows 160 GB in the BIOS.
Aanand is offline
Old 09-12-2005, 12:22 PM   #2 (permalink)
windows calculates 1 GB= 1024 MB
HDD makers calculate 1 GB= 1000 MB
thats y
Shwetanshu Srivastava
shwetanshu is offline
Old 09-12-2005, 01:37 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
thats y
thnx. i didnt no that !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 09-12-2005, 02:24 PM   #4 (permalink)
Learner
Kniwor's Avatar
ok (160*1000)/1024 = 156.25 Gb....
So where is the extra 4.25Gb...
Actually there are 2 reasons...
one is that which is stated above...
another is ur filesystem.... everyfilesystem has some header etc as i believe... so i dont think entire space is usable... but that's my interpretation...
Kniwor is offline
Old 09-12-2005, 02:53 PM   #5 (permalink)
Actually, you should be calculating 160*1000*1000/1024/1024=152.587890625 because HDD makes also consider 1KB as 1000Bytes... whereas in Windows 1KB=1024 bytes... the 1024 is actually used because it is 2 raised to the power of 10... HDD manufacturers make use of the fact that it is close to 1000.
Arun
sakumar79 is offline
Old 09-12-2005, 03:43 PM   #6 (permalink)
@skumar said it right, i thought that if i just mentioned that it wud have helped, gues i shud have explained full procedure
Old 09-12-2005, 03:53 PM   #7 (permalink)
shwetanshu is rite about the 1000 and 1024 thing..but dont only calculate 1024 mb,,,even the kbs and bytes are 1024 wich they rite as 1000 so u gotta calculate rite from d BITS
but SONY is cool...if u buy memory sticks, etc and u read the box, it says how much actual memory u get...like according to 1024..
ishaan is offline
Old 09-12-2005, 03:55 PM   #8 (permalink)
Learner
Kniwor's Avatar
Arun
wow... thanks...
I was thinking that the headers are created after the partition is formatted and was a bit confused and hence added that it was what i thought...
anyhow thanks....
Kniwor is offline
Old 09-12-2005, 07:43 PM   #9 (permalink)
ishaan buddy u dun have to calculate from the bits
only from the bytes => kB
since 8 bits is one byte and thats standard both for manufactures and windows
No Mercy, No Limits.
theraven is offline
Old 10-12-2005, 12:37 AM   #10 (permalink)
SONY makes mem?
ashnik is offline
Old 10-12-2005, 12:53 AM   #11 (permalink)
dIgItaL_BrAt's Avatar
He means the Sony Memory Stick (Pro,Duo whatever...) range.
dIgItaL_BrAt is offline
- by gforz
