Old 15-10-2004, 04:32 PM   #1 (permalink)
Default Remote CD writing
Hi All
Is there any software to write files from local hardisk to remote cd writer?
Let me thing clear. I have two pc connected with 100mb switch network.
One pc running windows 2k pro and other Windows 2000 server with sp4.
I have a cd writer installed at Windows 2000 server pc. Now i want to write files from win2k pro pc to win2k server pc.
Is there any software avilable to do this job ? free or trial version ?
I can use 2000 server but users are generally working on it.
Think of me n I will be there
amistik is offline
Old 16-10-2004, 12:09 PM   #2 (permalink)
tuxfan's Avatar
Actually, it is not advisable to do it like this. You may encounter buffer under run issues and may lose some CD-Rs.
Copy all the files from the other PC to local hard disk and then burn them.
tuxfan is offline
Old 16-10-2004, 12:29 PM   #3 (permalink)
Yeh. Thats right. But if i choose low speed wrting say 2x or 4x then i can address this issue coz my network is 100 Mbps switched with full duplex . Other wise if i got a software such that it has two part one server and other agent, when i submit writing job to agent it sends all data to sever then write the cd.
Now the question is - is there any software avialble to do this job. I Googled it but yet to find any one.
amistik is offline
Old 18-10-2004, 11:27 AM   #4 (permalink)
tuxfan's Avatar
Whatever be the speed of network and at whatever speed you may write, this setup is likely to cause BURN errors.
But I am not an expert. You can wait for someone who knows more than me on this
tuxfan is offline
Old 18-10-2004, 09:19 PM   #5 (permalink)
Well dude , i dont know about remote cd writing software but
You can try Vnc , (Virtual private network) , with this you can see the remote machine view on your desktop.And you can start your CD recording software on remote machine(Nero).
BlAsTeR is offline
Old 18-10-2004, 11:55 PM   #6 (permalink)
alib_i's Avatar
i've tried vnc ... its good
but y use it if you can use window's own "remote desktop"
im in a network like u amistik .. and to tell u
remote desktop rocks ... i use it everytime ..
-Metallica
alib_i is offline
Old 19-10-2004, 01:20 AM   #7 (permalink)
remote cd writing is really not worth recommending .. better do the copying on the same machine
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 19-10-2004, 12:01 PM   #8 (permalink)
tuxfan's Avatar
I just saw that Network Neighbourhood is not shown in Nero. So directly they don't support remote writing.
But you can MAP the remote drives and it will show them in the list. Then you can directly use Nero to do what you want to do. No need of any other software.
The above thing works in case you want to write remote files to local writer.
If you want to write local files to remote writer, you can share the remote writer (thru the remote machine), map it in the local machine and then may be Nero will pick it up. I've never tried this, but it seems logically possible. I don't have Nero installation CD handy. Otherwise would have instantly tried this and told you. But can try it out in a day or two and let you know.
tuxfan is offline
Old 20-10-2004, 04:27 PM   #9 (permalink)
Thankx Tuxfan for this idea using nero and network drive. I have allready check this issue before posting this topic. Actually when Nero starts it scan all channels including ide,scsi,usb etc if there is any cd drive attached. For Network map device it treats as just normal drive.
As mentioned by BIAsTeR, VNC will surely do the job. But problem is, its brings entire remote desktop to local machine. And if any user is currently working on that machine, he may feels irritatiing coz he has no controll over his mouse and keyboard.
Presently i am checking Paragon CD emulator. It is a nice software. But still it is for local machine.
amistik is offline
Old 21-10-2004, 09:36 AM   #10 (permalink)
GameAddict's Avatar
Default You may try NeroNet....
Hi,
Please see thsi link, it might be useful....
http://www.cdr-zone.com/download/CDR...3/neronet.html
Bye!
GA
GameAddict is offline
Old 21-10-2004, 01:20 PM   #11 (permalink)
tuxfan's Avatar
You are right. Actually, I realised this as soon as I disconnected the net connection. But couldn't log in again because of some work. Nero can write only thru local CD-Writers.
BTW, GameAddict has provided a good informative link. He seems to be burning lots of CDs But for it to work, you need an IP-capable intranet. I don't really know what it means, but check out the interface of the software thru the link given there. I don't think it is a shareware/freeware.
tuxfan is offline
Old 21-10-2004, 01:41 PM   #12 (permalink)
Bewitched!
xenkatesh's Avatar
Hey dudes check this out windos expert itself give u solution for this
just follow the link
http://www.microsoft.com/windowsxp/u...January28.mspx
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 25-10-2004, 05:46 PM   #13 (permalink)
Thankx GameAddict. Its a good linking. I allready downloaded the trial version of NeroNet and will check it shortly.
As mentioned by tuxfan IP capable intranet means local lan with ip address. Not netbeu type. For CD Writer Server I have to assign a fixed IP address
amistik is offline
Old 25-10-2004, 09:31 PM   #14 (permalink)
tuxfan's Avatar
Oh!! Is that so? I didn't know Thank you for telling me. I didn't know I already had a IP capable intranet in my office
tuxfan is offline
- by gforz
