Old 09-12-2005, 01:05 AM   #1 (permalink)
Default Modify The System Properties!
I have an IBM ThinkCenter.
When I go to the system properties, a dialogbox appears with multiple tabs. There are two pictures in the General tab. One is at the upper half displaying a computer, and other, at the bottom half displaying the IBM logo. Earlier in a digit issue, at take a crack, there was a challenge to change the picture at the upper half. Now i wanna know, how to EXACTLY change the pictue on the bottom half, in my casem the IBM logo, with say any other picture!!!
http://ravishchandra.blogspot.com
http://ravifriendz.co.nr/
Ravi.
http://ravishchandra.blogspot.com/
Ravi+ish is offline
Old 09-12-2005, 03:20 PM   #2 (permalink)
hansraj's Avatar
MAN TRY USING RESOURCE HACKER .... U MIGHT BE ABLE TO DO IT
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 09-12-2005, 03:28 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
if u go to ur System32 folder, u will find a BMP file called OEMLOGO.bmp which contains that IBM image...
Replace that image with that of yours and enjoy
Harsh J
www.harshj.com
QwertyManiac is offline
Old 09-12-2005, 10:57 PM   #4 (permalink)
Thanks!
Ravi.
Ravi+ish is offline
- by gforz
