Old 08-12-2005, 07:04 PM   #1 (permalink)
Default Please tell me how to locate .swf files loaded from websites
Hi friednds
Can you mention where does the .swf files goes while loading from websites.
& how to search them manually, without software.
Thanx in advance
ah wretch !
what evil looks
vijesh is offline
Old 08-12-2005, 07:15 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
they will most prolly be in the Temporary internet Files folder under windows when using IE, for FF its in Local Settings / xxxxxxx under ur userr name in Documents and Settings ... Search using Start > Search and type in *.swf
QM
QwertyManiac is offline
Old 09-12-2005, 09:43 AM   #3 (permalink)
ramprasad's Avatar
1. In ur browser, go to View ---> Source
2. In the source displayed, search for "swf" to get the name of the Flash file.
3. Go to C:\Documents and Settings\username\Local Settings\Temporary Internet Files and locate the file.
Mind u, Local Settings is a hidden folder. Go to Folder Options in CPL to view hidden files.
ramprasad is offline
Old 09-12-2005, 10:30 AM   #4 (permalink)
aadipa's Avatar
I use FlashSave Plugin for Maxthon to do that.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 09-12-2005, 05:01 PM   #5 (permalink)
Thanx but 'source' is hidden in some cases under VIEW menu.
Then what to do?
ah wretch !
what evil looks
vijesh is offline
Old 09-12-2005, 05:05 PM   #6 (permalink)
Commander in Chief
Right Click on the main window and an option of View Source will be there in IE/FF/Opera et all..
QM
Old 11-12-2005, 12:45 PM   #7 (permalink)
or better in firefox right click on main widow select view page info then click media tab select what u want to save and then click save as simple!!!!
allmighty is offline
Old 16-12-2005, 02:57 PM   #8 (permalink)
goto temperory iternet files and put the files in"arrange by size"
then go the end of the folder where obviously the large sized .swf files will be placed
WHEN THINGS GO WILD CYBO GET WILDER
LINUX ROCKS
WIND SUCKS
its still sucking
cyboincomp is offline
- by gforz
