08-12-2005, 06:40 PM
more devices than pri & sec mas & slave
hi,
i already hav 2 hardisks(IDE) and 2 DVD roms(reader + writer) connected. i am in need of more space and planning to get another hardisk. I hav 865 chipset.. but am in fear to get a SATA coz, the earlier one(120 B) got burnt. how can i get more IDE hardisks connected? also, i hav external hardisks. but i need to connect IDE controlled hardisks only. is there any way?
/legolas
08-12-2005, 06:50 PM
SATA HDDs are usually better in performance than PADA HDDs. Your SATA HDD failure might have been an stray incidence, but you can go for SATA HDD inspite of it... If you want, you can go for a different brand (if you had used Samsung, try Seagate and if you had used Seagate, try Samsung... or go for another brand such as Western Digital, Hitachi or Maxtor).
Dont know if you can go for more than 4 IDE devices...
Arun
08-12-2005, 07:08 PM
SNIST Screamer !!
wat do u mean by " also, i hav external hardisks."
whether u connect another HD on the IDE is totally dependent on ur mobo
most mobos have only 2 ide connectors
and these days SATA is the norm
i advice u to go for SATA,
if not with no IDE connectors available ,external HD is ur only option
which will twice as tht of a SATA disk !!!
08-12-2005, 07:19 PM
Re: more devices than pri & sec mas & slave
Originally Posted by legolas
hi,
/legolas
I think you can, by using an IDE PCI Card.
V.Prem Kumar
08-12-2005, 10:31 PM
yeah, something like tat is wat i am looking for... is taht available??? is it worthy? i wud also consider havin SATA... cud u suggest me 1 good company of the many listed here in ur opinion... coz its my SATA seagate hardisk that burnt in 3 weeks!
/legolas
08-12-2005, 10:36 PM
SNIST Screamer !!
i think u better understand how ur SATA disk got burnt !!!
i am sure its not coz its a SATA disk !!!
take my word and go for SATA
if u r still reluctant then check these for the IDE pci cards
they cost around 1300 bucks which i think is a waste
check this link for them
http://search.ebay.in/search/search....%26catref%3DC6
09-12-2005, 09:49 AM
In Pursuit of "Happyness"
Go for Western Digital or Maxtor SATA.
09-12-2005, 11:12 AM
Hi vijay_7287,
May I know the reason , why do u think PCI IDE cards are waste...?
09-12-2005, 04:14 PM
hi,
yes, i wud also like to know the reason for ur considering it a waste!! and could any1 tel me a local service center which wil be able to replace the burnt part of my hardisk PCB, available in chennai? thk u.
/legolas
09-12-2005, 04:32 PM
Hi legolas,
Take it to Richie street. There are many shops which repair burnt HDD boards
09-12-2005, 10:49 PM
check out for RAID.....
Search this Thread |
