Old 07-12-2005, 06:33 PM   #1 (permalink)
Generic Superhero's Avatar
Default how spyware intrudes?
1.how does a spyware get installed in a sys from a website?
2.a)ff=no spyware ?
b)ff+noscript extension=no spyware??
Nipon
Generic Superhero is offline
Old 07-12-2005, 08:13 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Spyware does get installed if u d/l some s/w and stuff and if a Trojan greets and d/ls it from ur comp...
No Script is just to blok javascripts which might harm...
If u got Sp2 and a good anti-spy then no worry as mostly it doesnt infect, jus resides as in my case...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 07-12-2005, 08:20 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
check this thread , u will more answers than the Q's u've got !!!
http://www.thinkdigit.com/forum/viewtopic.php?t=11368
vijay_7287 is offline
Old 07-12-2005, 08:30 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
common possibilities are :
u visit some malicious site, it sends a trojan in ur temp internet file, which in turn donwloads and installs the malware wthout ur knowledge.
u install some somtware saying yes yes yes to everything, without reading the small print, and then say, 'hey iv got spyware' !
to kya kare ?
simple..this is what ive done.
replaced my host file (http://www.mvps.org/winhelp2002/hosts.htm)
added spware sites to my restricted sites zone ('ie-spyads')
used the 'computer security tool'
and use ms antispyware and spywaredoctor.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 22-12-2005, 07:00 PM   #5 (permalink)
anandk's Avatar
Read : Top 10 tricks causing spyware epidemic
http://blogs.zdnet.com/Spyware/?p=729&tag=nl.e589
Microsoft® MVP
anandk is offline
- by gforz
