Old 07-12-2005, 12:00 PM   #1 (permalink)
Asterisk enthusiast
abhasbajpai's Avatar
Default help!!! my .scr files (screen savers)are assocate to notepad
help !!! i am facing a wired problem my .scr files are attached to notepad in my winxp sp2 system.
now when i click or right click>open a .scr file thwy open notepad
the work fine with screen saver tab
now i want with wich programe .scr are assocated with so that i can assocate them with right applet
help needed
abhasbajpai is offline
Old 07-12-2005, 12:28 PM   #2 (permalink)
Try http://www.dougknox.com/xp/fileassoc/xp_scr_fix.zip
Arun
sakumar79 is offline
Old 07-12-2005, 07:27 PM   #3 (permalink)
Asterisk enthusiast
sakumar79
thanks for help i ll certenly try it
Old 07-12-2005, 11:07 PM   #4 (permalink)
u can evn try
http://www.roger.id.au/downloads/ass...xp_scr_fix.reg
its a link in dis site - http://www.roger.id.au/tweaks/fileassoc.php
which has a list of many file extensions u can restore
ishaan is offline
Old 09-12-2005, 12:17 PM   #5 (permalink)
Asterisk enthusiast
thanks guys
it realy help me
thanks again
- by gforz
