Old 06-12-2005, 09:24 PM   #1 (permalink)
sujeet2555's Avatar
Default disk partioning
i wanna know,can i partition or join the partions without losing the data on them.how?
s.k.
sujeet2555 is offline
Old 06-12-2005, 09:28 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
u need to use norton partition magic
mind u its a shareware !!!
vijay_7287 is offline
Old 06-12-2005, 11:33 PM   #3 (permalink)
choudang's Avatar
you can try with Ranish Partition or Parbeta HDD tool.. its free.
For every action, there is an equal and opposite criticism.
choudang is offline
Old 06-12-2005, 11:56 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Or u can serach the forum
Already discussed so many times............
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 07-12-2005, 12:05 AM   #5 (permalink)
you can use partion magic software for this...
rkharikrishnan is offline
Old 10-12-2005, 12:42 AM   #6 (permalink)
Please read the help file of the software before u partition.Never try merging primary partitions.
hsksattish is offline
Old 10-12-2005, 12:59 AM   #7 (permalink)
dIgItaL_BrAt's Avatar
Try BootIT NG .It's free and it has a GUI.
dIgItaL_BrAt is offline
Old 11-12-2005, 08:07 AM   #8 (permalink)
Nobody garentees your data. It is prone to loss.
Once I merged two I lost the data in both - I use Partition Magic 8) Since I have DVD backupsof all the data, they are retrieved.
Yesterday - Dead
Today - Dying
Tomorrow - Never dies
The day after tomorrow - Where will you be !
Sreekanth V is offline
Old 11-12-2005, 10:23 AM   #9 (permalink)
try these softwares :
1.)partiton logic
http://www.softpedia.com/get/System/...on-Logic.shtml
2.)CompuApps-SwissKnife
http://www.download.com/CompuApps-Sw...ml?tag=lst-0-4
3.)Paragon-Partition-Manager
http://www.download.com/Paragon-Part...ml?tag=lst-0-9
hope its of use to you.
calvin is offline
- by gforz
