Old 15-10-2004, 03:37 AM   #1 (permalink)
Default PICTURE OF WORLDS MOST FAMOUS...............
Whenever I insert in a floppy a file named-
PICTURE OF WORLDS MOST FAMOUS............... appears.
Every floppy gets affected. No antivirus detects it as a virus. But i still doubt its a virus. As to whomever I give the infected floppy that person also faces the same problem
Due to this reading of the floppy becomes slow.
Please help.
Wat 2 du?
Aseem Nasnodkar is offline
Old 15-10-2004, 07:42 AM   #2 (permalink)
Did you try formatting ur floppy drive ?
Vande Mataram - Two words that became a Fiery War Cry and Electrified the nation towards Freedom. A mantra that instills a sense of Pride and belonging.
go4inet is offline
Old 15-10-2004, 10:16 PM   #3 (permalink)
sujithtom's Avatar
Hey I have heard about it. Its a virus, i am sure about it. I read about it somewhere...
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
Old 16-10-2004, 06:38 PM   #4 (permalink)
format the floppy.
if that doesn't work chuck the floppy - floppies dont cost much anyway
(but before that update your antivirus software and scan it again)
the geek speaks again
i_say_hello is offline
Old 21-10-2004, 03:27 PM   #5 (permalink)
Bewitched!
xenkatesh's Avatar
ya i tooo it is a virus dude!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 21-10-2004, 04:35 PM   #6 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
It's a virus!! A pretty old one.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 21-10-2004, 06:22 PM   #7 (permalink)
Another Brick in the Wall
drgrudge's Avatar
put the latest antivirus signatures and scan for any virus....
why dont u discard the floppy?
drgrudge is offline
Old 21-10-2004, 07:04 PM   #8 (permalink)
It seems to be a virus. Go to AVG or mc afee 's site and get free online virus scan done.
Shikhar is offline
Old 22-10-2004, 12:03 PM   #9 (permalink)
By Pressing ctrl+alt+del , Stop unknown programs running.
In Run type msconfig , Disable all unknown startup entries.
And if you are runing win 2000 or xp In run type services.msc and stop and disable unknown services.
And atlast make floppies write protected if you do not wish to write any thing on to it.
Bcoz what that virus does is , keep running in background and check for floppies. If floppy is detectd it coppies it self in form of a image or exe file.
My friend had same problem with manisha.exe
So be careful it affect every sys where that floppy is inserted
BlAsTeR is offline
Old 11-01-2005, 12:15 AM   #10 (permalink)
Try this anti-virus:
Avast home edition 4.5
http://www.avast.com
My favourite! 8)
Intel P4 2.6 GHz HT + Intel D865GBF mobo
512 MB DDR 400 MHz RAM
80 GB SATA HDD
128 MB XFX GeForce FX 5700 LE
tejesh is offline
- by gforz
