Try any one of the options:
1. You can use
BSPlayer.
Just click and drag the .srt/other subtitles file to the playing area of the media player. Now It will play fine
2. If you want to use
VLC player , then there is an option to add subtitles as well. But you need to play the file by starting the VLC player and not clicking on the movie file as such.
3. Using
Windows media player, BSplayer, and few other players and using vobsub.
Follow this:
1. Make the .srt and .avi( or whatever) the same name. You have done this. Except for the file extrnsion, everything should be the same, so when you look there should be two files in the same name, only their icons be different.
2. Now place them both in a folder. Name the folder also in the same name, but this is not required, but still do this.
3. Now open the file, the vobsub should load (and hence the .srt)
4. Even oif the .srt dont load, then maunally start vobsub. Now make sure that vobsub is working by just starting it.
That should help you.
Why all this trouble? Just d/l BSplayer and drag the .srt to the screen and the subbies load fine!
4. Also you can try:
Divx Subtitle Displayer http://www.cooolsoft.com/
Moved to QnA
