Old 05-12-2005, 06:02 PM   #1 (permalink)
jay4u's Avatar
Default Help choosing for Dual Monitors
I want to go the Dual monitor way... i have my recommendations.... please have a look and sugest me the graphics card and monitor and the approx costs.....
monitors need to be 17"..... i thinking of samsug 17" Magicbright series flat CRT
graphics card... range is 8-10 k... should have dual monitor output... i mean 2 vga o/p to connect the monitors and should also support for lcd outputs... i have pci x16 and intel 915 gavl
and this should support my current UPS of 600 vA...(if not then sugest how much vA UPS should i buy)
Passwords are like underwear... Change them often...
jay4u is offline
Old 05-12-2005, 06:10 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
for the 10k range of course the 6600gt
and i think the 600va will do
and even the choice of monitors is pretty ok !!!
(but 2 crts side by side thts a lot of space )
wrong section i suppose !!!!
vijay_7287 is offline
Old 05-12-2005, 06:30 PM   #3 (permalink)
jay4u's Avatar
YA but i can get tese two CRT for the price of one....... and what about the UPS is 600 vA sufficient for a 6600 gT 400 watts pwersafe PSU and 2 CRT monitors....
And sorry for posting in wrong section...... can moderator please change this thread under hardware troubleshooting .....
jay4u is offline
Old 05-12-2005, 06:43 PM   #4 (permalink)
gxsaurav
Posts: n/a
if u can find a Geforce 6200/5200 with dual DVI then go for it, & save money, unless u plan to game
Old 05-12-2005, 10:32 PM   #5 (permalink)
jay4u's Avatar
I want to make it a bit future proof too like 6600 GT to run Vista with all effects on...... and about my UPS problem .... can someone answer... gxsaurav
jay4u is offline
Old 05-12-2005, 11:45 PM   #6 (permalink)
gxsaurav
Posts: n/a
6200 with 128 MB RAM, non turbocache will be compatile with Vista, even 5200 with 128 MB RAM will do
Old 06-12-2005, 04:35 PM   #7 (permalink)
jay4u's Avatar
thanks gxsaurav..... but i think a 6600 GT is a must for playing present games and future games... but does 66oo GT needs an external power supply or the pciexpress is okie...????
jay4u is offline
- by gforz
