Old 04-12-2005, 12:06 PM   #1 (permalink)
Default How to load php scripts in apache
hi guys
I have recently setup apache server on my pc with all necessary modules like mysql, php4.1 etc.
Now i want to load php scripts on my apache server.
Can anybody guide me step by step how to setup scripts like contact form etc in apache server (I want to create online database).
I am novice in php.
Techmastro is offline
Old 04-12-2005, 09:43 PM   #2 (permalink)
come on guys have no body ever used apache server or installed php scripts.
Old 05-12-2005, 10:23 AM   #3 (permalink)
Version 2.0
Deep's Avatar
hmm there is nothing to setup basically...
to check if your script is running properly or not, create a file in htdocs folder with name phpinfo.php (or any name u want)
put this code in that
<?php
phpinfo();
so if you find php info when you visit the page, that means PHP is installed and you can play with it...
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 05-12-2005, 10:49 AM   #4 (permalink)
I don't know what you are having problems with, just put php files in root and they will be executed upon access (since you have php installed). If you need scripts just go to hotscripts.com and find any form to mail script to create a contact form.
wORm is offline
Old 05-12-2005, 11:11 PM   #5 (permalink)
NikhilVerma's Avatar
<?php
phpinfo();
Deep
And to execute it ... Type
localhost/phpinfo.php
In your browser and make sure that apache is running...
NikhilVerma is offline
- by gforz
