Old 01-12-2005, 07:03 PM   #1 (permalink)
Default Solution to create "con" folder....
Hello digitians,
I am giving here the solution, Syntax for Creating "Con" folder, and
Reason....
To Create a directory with name "Con" at C:\ root, Syntax is....
command prompt> mkdir \\.\c:\con
To Delete this folder....
command prompt> rmdir \\.\c:\con
Reason... why u cant create folder in normal way from window...
DOS device names are reserved words, and cannot be used as folder or
file names. When parsing a reference to a file or folder, Windows
correctly checks for the case in which a single DOS device name is
used in the path, and treats it as invalid.
And a CAUTION....
The following reserved device names cannot be used as the name of a
file:
CON, PRN, AUX, CLOCK$, NUL, COM1, COM2, COM3, COM4, COM5, COM6, COM7,
COM8, COM9, LPT1, LPT2, LPT3, LPT4, LPT5, LPT6, LPT7, LPT8, and LPT9.
You must avoid using these names as a file name suffix or file name
body, so you have to avoid names such as aux.c, file.aux or NUL.txt.
OK then..
Bye.. Waiting 4 your comments...
krdevilal is offline
Old 01-12-2005, 07:05 PM   #2 (permalink)
http://www.thinkdigit.com/forum/view...30333&start=20
already solved
Shwetanshu Srivastava
shwetanshu is offline
Old 01-12-2005, 09:35 PM   #3 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
Thanks Shwetanshu for taking the trouble of searching for and posting the links.
Thread locked.
The ANGRY Pixel proudly announces the launch of India's first ever launch center for a game, The ANGRY Pixel - Milestone Interactive Street Fighter 4 Launch Center
ctrl_alt_del is offline
- by gforz
