Old 30-11-2005, 10:11 PM   #1 (permalink)
Default P2P FILE SHARING PROBLEM --- PLEASE HELP
Hi,
I could not use p2p file sharing feature. I am using LAN for internet connection. I am behind NAT ROUTER(probably 3), proxy, L2,L3 switches. I have no access right to modify their configuration. I am using azureus for client programme. I check NAT problem and found sleath in test. The port 6881 ,6969 or 7000 is not opened.
Is there any way to bypass all this , or any tools is available so that I can use file sharing feature without any problem.
Please help...
Thanks in advance..
shersaha is offline
Old 01-12-2005, 02:27 PM   #2 (permalink)
siriusb's Avatar
If the ports are stealthed, then you do have a nat problem. If u have no access to the nat or router, then you cannot do anything man. If u have access, then you can try port forwarding on the said nats. Or you can ask the network admin to arrange it for you. You cannot bypass using any tool or it would defeat the purpose of a nat.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 02-12-2005, 01:49 PM   #3 (permalink)
u can try changin the ports used by the p2p clients to something wich is not blocked...
btw, i think u should use BitComet instead of azureas cuz azureas takes a lotta system resources n i hav usd both i found bitcomet 2 b btr...and i dono abt azureas but i remma bitcomet had an option to change the port number
ishaan is offline
Old 02-12-2005, 02:18 PM   #4 (permalink)
siriusb's Avatar
I doubt that an organization that deploys 3 levels of nats will have even one ports open. But you can try to do a port scan at some security site.
And azurues does support changing ports. Azureus is not a big ugly dumb program like ppl take it to be. It is *the* advanced (and best, imho) BT client out there. But it's not for the weak of computers for sure. But I myself run it 24/7 in the background, while I game or do whatever in the foreground.
siriusb is offline
Old 02-12-2005, 03:02 PM   #5 (permalink)
i tried playing quake 4 with azureas running in d background it kept hanging but with bit comet its fine
anyways, i was asking...wat happens if u set the p2p port to 80 ? will it work or interfere with http? and wat exactly will happen if it interferes?
ishaan is offline
Old 04-12-2005, 07:29 PM   #6 (permalink)
siriusb's Avatar
I probably have a faster machine then. I've run cod2 and NFSmw with no snag.
Anyway, I don't think his port 80 will be open coz I don't think the org expects inside ppl to run servers; it's NATed. If your port 80 is open then you can very well use it. Any open port will do. But avoid the ones with a server running on it.
siriusb is offline
Old 05-12-2005, 09:17 AM   #7 (permalink)
port 80 is open can i use azureus on this port .. why p2p software not used port 80 insted of other port which is most probably blocked for security reason.. can p2p software be used on port no. 80 please. As I can access website (http,https) , I think port 80 is open .If it is not open then how can i access web pages and can download software and other things?
shersaha is offline
Old 05-12-2005, 10:50 AM   #8 (permalink)
siriusb's Avatar
Er, no. Browsing websites doesn't require/mean that your computer has an open port, because you are only running a http client (your browser). If u are running a server (apache, iis), then you need an open port to run the server on.
The 'open' is as seen from the 'outside' or from the Internet; not from your side. But if you can scan the ports using some online tool and find that you have port 80, 21 or any other reserved port open, and you don;t have a server running on that port, then you can very well ask azureus to use that port.
siriusb is offline
Old 05-12-2005, 11:04 AM   #9 (permalink)
dear siriusb,
can you help me to find some online tool for port scan so than i can find what port is open or not?
in my computer there is no server is running. I am using this connection through LAN where porxy/server is running. How can i test that proxy, server port is open or not?
shersaha is offline
Old 05-12-2005, 01:59 PM   #10 (permalink)
u can find some here - http://www.cotse.com/tools/pscan.htm
ishaan is offline
- by gforz
