Old 30-11-2005, 07:47 PM   #1 (permalink)
Default Where my hidden folders?
Hello!
Today wehn i wanted to veiw my hidden folders and system files
i was unable to do it as there was no option such as " folder options "
in my tools menu i did only contain - mapr network drive,disconnect network drive and Syncrhonize. I even went to my Control Panel to check Folders but it wasn`t there
Please Help Me
Thnx
rambo is offline
Old 30-11-2005, 08:25 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
try findin tht in the classic menu of the control panel
or try gettin tht in the tool bar
if the above dont work
then there is this tweak for enable/disable folder options in WinXP manager
try tht and i am sure it will sove the prob !!!!
vijay_7287 is offline
Old 30-11-2005, 10:41 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Start -> Run and type regedit, It'll open Registry Editor. Then nevigate to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer
In right-side pane, u'll see a key named:
NoFolderOptions
And its value will be 1.
Simply change its value to 0 or delete the key...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 01-12-2005, 03:35 AM   #4 (permalink)
yrana2002's Avatar
Another may be the following dos command:
Supposing your problem is c:\windows----
C:\windows>attrib -h
This changes its attributes to unhidden. Since most of the hidden files are in root directory, try opening that! 8)
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 01-12-2005, 07:59 AM   #5 (permalink)
Let the music play.....
djmykey's Avatar
Dood check the account you are using maybe u dont have sufficient rights to change the attributes so log in with some admin account and then try it out again.
djmykey is offline
- by gforz
