i am using computer in library which is connected in LAN. i can dowload anything from the internet but when i run messenger any .. then computer shows the problem . what should i have to do..
wwwX.meebo.com is right. well u just need to type www.meebo.com then it will take the server with min load. BTW bshreshtha, there are some problems with MSN 7.5 (latest release), but the prob was gone when I reinstalled it. try uninstalling and re-installing. it may help u too.
