Old 29-11-2005, 11:35 PM   #1 (permalink)
Default sms with yahoo messenger
Hi all,
I've mail id on yahoo.com...I can't send sms on any mobile in India. Will I be able to do that if I've a id on yahoo.co.in.
Thanks
jack// ani is offline
Old 29-11-2005, 11:39 PM   #2 (permalink)
You can send messages through the Yahoo Messenger
If you want a good sms site www.sms.ac.in
rachitar is offline
Old 29-11-2005, 11:48 PM   #3 (permalink)
Dunno wats heppening to you.
I also have a yahoo.com id, But I can send sms's to any mobile in india except BSNL Cellone.
Why not Celone?
Even I dont know this answer.
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 29-11-2005, 11:55 PM   #4 (permalink)
Well.. when ever i send any msgs... i see the failure msg that the no. is not served. I looked for the format of the no. that gotta be used. And entered +91994546xxxx and I got that msg. If u used any other format tell me. Tell me exactly what u did.
Other than Yahoo. i used Chikka by indiatimes It sends SMS to all in india and the east countries. But, with airtel there's a prob. The airtel user is not able to reply!!!!
Ravi.
http://ravishchandra.blogspot.com/
Ravi+ish is offline
Old 30-11-2005, 08:24 AM   #5 (permalink)
Yes, sometime I also face the same probelm and sometimes it says......Phone number 919300xxxxxx cannot receive text messages at this time. Whats the problem guys...
Old 30-11-2005, 11:52 AM   #6 (permalink)
Yahoo messenger doesnt support sms to bsnl mobile service !
Smile a lot
it costs nothing
sumit_ind is offline
Old 30-11-2005, 12:27 PM   #7 (permalink)
but i'm trying to send sms to rim.
Old 01-12-2005, 12:37 AM   #8 (permalink)
Why not Celone?
r u able to send sms to Reliance & tataincomm ?
Currently i am using www.sms.urspider.com
minniawochat is offline
Old 01-12-2005, 01:20 AM   #9 (permalink)
hey jack u can send sms to some mobiles but only 3 messeages u can send after that u need a reply from ur frnd & then u can send 3 more
to tata indicom mobile register at www.smscountry.com
& u can send 1 free sms daily to any indicom
gycapri is offline
Old 01-12-2005, 09:17 PM   #10 (permalink)
i think yahoo doesn't support cdma............. its only for gsm......... so wid reliance it may not work............
satbir is offline
Old 01-12-2005, 11:08 PM   #11 (permalink)
@Rachitar
That link is going for a school
ashnik is offline
Old 02-12-2005, 01:17 AM   #12 (permalink)
No, No.... it does send sms to CDMA ang gsm both!!! With my experience i think ... it's just some kind of a thing that some ppl are having problems with some nos. only..
I SUGGEST try to use a cyber cafe for the no... you are not able to send to from home!!
Ravi.
Ravi+ish is offline
- by gforz
