Old 29-11-2005, 02:58 PM   #1 (permalink)
Default Blue screen error!!!
hai guys, i am frequently getting a blue screen with a message "Page fault in non paged area" can anybody tel me wats wrong with my pc,wat should i do?
shay4u is offline
Old 29-11-2005, 06:02 PM   #2 (permalink)
Netjunkie's Avatar
Can you post more details on when does this occur. What programs are you running? Did you upgrade your drivers recently?
You can generally see a "Stop Code" associated with such messages. Check out this link to know what they signify.
Netjunkie is offline
Old 29-11-2005, 06:14 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
same question....
next i would suggest that try switching RAM modules... & change the windows Page file size & location...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 29-11-2005, 11:36 PM   #4 (permalink)
it usually occurs when i login or try to start an application. i have updated my graphics n sound driver. i hv changed my motherboard to intel 845glva,b4 i was using a chipset board of someother brand.
shay4u is offline
Old 29-11-2005, 11:46 PM   #5 (permalink)
Rebooting
& after that, i hope, u have made a reinstall with proper drivers...
rebooting
ChotoCheeta.com
Old 29-11-2005, 11:46 PM   #6 (permalink)
I think there is some kind of corrupt-ness in ur system. Some kind of mismatch. Try installing the drivers again. If that doesn't work, format the system, save ur imp. files(first), and then reinstall everything.
Ravi.
http://ravishchandra.blogspot.com/
Ravi+ish is offline
Old 30-11-2005, 03:10 PM   #7 (permalink)
i hv formated the system n tried many times... but same problem.
shay4u is offline
Old 30-11-2005, 09:48 PM   #8 (permalink)
dIgItaL_BrAt's Avatar
have u tried installing service pack 2,that solved the problem in my case.
dIgItaL_BrAt is offline
- by gforz
