Old 13-10-2004, 08:08 AM   #1 (permalink)
tweety_bird_bunny's Avatar
Default recovery dos mode...
plz tell me some recovery software through which i can boot into my system & recover files if my windows become corrupt or something like that.... it'll be good if it has Graphics interface...
tweety_bird_bunny is offline
Old 13-10-2004, 10:33 AM   #2 (permalink)
Ontrack Easy recovery Pro can pretty much do it. Its got an excellent GUI and supports fat and ntfs, of course you can use a mouse.. However, it doesnt support RAID and other advanced setups
If you want something more easy to use to aid recovery, you can try out Winternals ERD commander . ERD commander is based on WinPE and thus you can get that familar windows look and feel- of course, you can run most windows programs too from ERD.
If you are lookin for a freeware alternative, then look out for recovery CDs based on BartPE. You can create your own live bootable XP (BartPE) cds, plus use standard Windows programs like GetDataBack for fat/ntfs. For more information on all this, please Google..
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
Old 14-10-2004, 04:06 PM   #3 (permalink)
Hey if u use windows xp
the best thing too do is to install the windows recovery console to ur hd.
Aftr u install it it gives u a option in the startup itself.
Juss click start>run and type
D:\i386\winnt32.exe /cmdcons
wer d is the cdrom drive letter in which u shud hav ur xp cd.
beyondthegracefgod is offline
Old 14-10-2004, 04:13 PM   #4 (permalink)
hey it dosent hav gui .(oops)
- by gforz
