Old 27-11-2005, 08:10 PM   #1 (permalink)
Default Yahoo Messenger - Please help!
Hi ppl!,
I am having a bit of a trouble with my Yahoo messenger!
I was using an ID for a long while... then I stopped recieving any offline msgs for than a couple of months! When i logged into the same messenger(I use it at home) , using other ID, then it worked! I use Yahoo Messenger 7.0. Everything else on that ID is working fine!
I have tried many things. I upgraded the messenger, earlier i had 7.0 BETA. I deleted all the profile and then logged in again. Nothing Worked. If you have any idea. Please tell me.
AND YOU PPL AT DIGIT. PLEASE LOOK INTO THIS AND HELP ME!!
Ravi.
http://ravishchandra.blogspot.com/
Ravi+ish is offline
Old 27-11-2005, 08:25 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
so speaking basically , logically , practically :roll:
u have not put problem anywhere there...... :roll:
out of wat i could make out of it u r not getting offline messages and thats the prob
well try sending an offline to that id from another id ,if it comes congts
if it doesnt well since u have not used it for months
i suppose yahoo might have deleted it !!!!!
vijay_7287 is offline
Old 27-11-2005, 08:25 PM   #3 (permalink)
__Virus__'s Avatar
1. Is anyone sending you offlines in very first place?
2. Is someone reading your offline before you do?
3. Did you try sending offline messages from other id you are using to the one having problems?
__Virus__ is offline
Old 27-11-2005, 08:29 PM   #4 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
Well thts wat i have asked him to do
why r u repeating it again ...................
Old 27-11-2005, 08:34 PM   #5 (permalink)
__Virus__'s Avatar
vijay_7287 Posted: Sun Nov 27, 2005 8:25 pm
__Virus__ Posted: Sun Nov 27, 2005 8:25 pm Post subject:
Hope that answers.
Old 27-11-2005, 08:40 PM   #6 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
well sorry VIRUS bhai ..........
when the name is VIRUS i guess people always have a prob with it !!!
SORRY again ......... :roll: :roll: :roll:
Old 27-11-2005, 08:43 PM   #7 (permalink)
__Virus__'s Avatar
No Probs whatsoever.
Old 27-11-2005, 08:47 PM   #8 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U can try 2 things!
1.) Goto: Program Files\Yahoo!\Messenger\Profiles folder and delete the folder with the name of ur User ID.
2.) Open regedit and nevigate to:
HKEY_CURRENT_USER\Software\Yahoo\Pager\Profiles
And delete the key with the same name as of ur User ID.
May be it help U...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 27-11-2005, 08:55 PM   #9 (permalink)
Yes yes!!! There are many ... who are sending the msgs. In fact, i got complains from my friends, that why am I not replying. Then, i came to know there's something wrong!
Ravi.
Ravi+ish is offline
Old 27-11-2005, 08:59 PM   #10 (permalink)
Well.. i did try and delete the profile... but didn't do that registry thing... Thanks.. i'll try that now!
Ravi.
Ravi+ish is offline
Old 27-11-2005, 10:17 PM   #11 (permalink)
Vishal: I wasn't able to fix the problem. You suggested to get into the registry and delete the keys containing...the id.. .but to my disappointment... there were no keys in the whole registry containing any of the ids that have been used!
Ravi.
Ravi+ish is offline
Old 27-11-2005, 10:18 PM   #12 (permalink)
Default Hey!
Originally Posted by Vishal Gupta
U can try 2 things!
May be it help U...
Ravi.
Ravi+ish is offline
- by gforz
