Old 25-11-2005, 09:46 PM   #1 (permalink)
Default Read write, ODBC....????
HI
WHat is ODBC and DNS?
IS it related to Read write permission to a folder in a webserver?
WHat is techinical name for Read write permission to folder. Becasue I want to know whether hosting companies gives read and write acces to folders?
Please help me I am new bie in database connection and asp.
Thank u
ranjithbajpe is offline
Old 25-11-2005, 10:09 PM   #2 (permalink)
puja399's Avatar
ODBC means Open DataBase Connectivity, a standard database access method developed by the SQL Access group in 1992. The goal of ODBC is to make it possible to access any data from any application, regardless of which database management system (DBMS) is handling the data. ODBC manages this by inserting a middle layer, called a database driver , between an application and the DBMS. The purpose of this layer is to translate the application's data queries into commands that the DBMS understands. For this to work, both the application and the DBMS must be ODBC-compliant -- that is, the application must be capable of issuing ODBC commands and the DBMS must be capable of responding to them.
DNS is short for Domain Name System (or Service or Server), an Internet service that translates domain names into IP addresses. Because domain names are alphabetic, they're easier to remember. The Internet however, is really based on IP addresses. Every time you use a domain name, therefore, a DNS service must translate the name into the corresponding IP address.
As u can see that there is no apparent relation between ODBC and DNS, and also between them and any folder access in any webserver. Those three are not interrelated.
If u are interested in database connection , then only ODBC should concern u.
puja399 is offline
- by gforz
