Old 25-11-2005, 02:30 PM   #1 (permalink)
Default PLEASE TELL HOW TO CONVERT .swf files INTO Flash Application
Hi friends
I have downloade several .swf files including some games from websites.
I have to open them with internet explorer.
However iwant them to make flash apllication so that i can open them in just one click.
Thanks in advance
ah wretch !
what evil looks
vijesh is offline
Old 25-11-2005, 02:47 PM   #2 (permalink)
Install Flash player then you can directly open the files.
Also to make them stand alone, open in flash player. Under file menu see if "create/make projector" option is enabled. If yes click it, it will generate an exe for that swf file and now you can play it w/o flash player or browser. [But this option may be disabled for files that are protected].
Hope it helps.
forsan77ever is offline
Old 25-11-2005, 06:14 PM   #3 (permalink)
Thanks forsan
I have macromedia flash flayer installed but it doesn't show in program files.
Well, thanks again & that too in advance
ah wretch !
what evil looks
vijesh is offline
Old 25-11-2005, 06:22 PM   #4 (permalink)
vignesh's Avatar
.swf is a flash format.Install a flash player from Macromedia website..
vignesh is offline
Old 28-11-2005, 09:53 AM   #5 (permalink)
hi,
Flash player does not show up in prog files list. right click on the .swf file and select "open with.." choose flash player from the list. Choose the option "always use this program to open these files".
Thanks
Old 28-11-2005, 09:58 AM   #6 (permalink)
hi,
Thanks
Old 28-11-2005, 10:12 AM   #7 (permalink)
hi,
Thanks
Old 28-11-2005, 10:45 AM   #8 (permalink)
hi,
Thanks
- by gforz
