LinkBack (1) Thread Tools Search this Thread Display Modes
Old 24-11-2005, 06:31 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Best codec/bitrate for re-encoding avi files?
I wanted to ask which codec is the best?i have some videos some are in xvid,some are in divx and wanna burn them on dvds as .avi files and not .vob.
Also what is the best bitrate to encode,some videos are 2000 kbps,1700 kbps some are 800 kbps,which is the most reasonable bitrate,i mean you can have ofcourse better quality at 1700 instead of 1400,but how much of a difference does it make?
I was thinking of re-encoding them with the best codec and bitrate so as to have the best quality but not very high file sizes
thanks
rachitar is offline
Old 24-11-2005, 07:36 PM   #2 (permalink)
i think you should make em divx cuz many players support divx nowadays n very few support xvid
as for the bitrate, it depends on each movie. if its a small movie, choose a higer bitrate. if its a bigger movie, choose a lower bitrate.
the aim is to make it fit in one cd. so mess around until u find the right bitrates for a normal full length movie, for half n hour episodes, for small clips, etc.
it would be nice if after u tried em out, u could post em here so ppl can jus use that for reference.
ishaan is offline
Old 24-11-2005, 07:59 PM   #3 (permalink)
Default Re: Best codec/bitrate for re-encoding avi files?
thanks
XVID - free, open source, FAST, beats DIVX everytime in Doom9's yearly quality comparisons.
Also, will work with all standalone players that are DIVX certified.
Best bitrate? - Use Gordian Knot and run the compressibility test before encoding.
Bottom line being, if you know how to make the best use of Gordian Knot (search for guides at doom9.net) you'll always end up with the best looking encodes.
-Keith
Keith Sebastian is offline
Old 25-11-2005, 12:02 PM   #4 (permalink)
jay4u's Avatar
basically xvid and divx are of same genre but xvid is supported by opensource... try it DUDE its rally good.... you can use something called Virtualdub.... if you want to make conversion really fast and in drag and drop manner then the best option is to use
Pocket DivX encoder
its simple and easy and fast... but the movies screen size is limited to around 540 pixels
Passwords are like underwear... Change them often...
jay4u is offline
Old 25-11-2005, 12:45 PM   #5 (permalink)
gxsaurav
Posts: n/a
Bitrate depends on the video resolution
for 352X288, use 512 kbps DivX 6
for 720X480, DVD resolution, use 1024 kbps, high quality & extreme noise reduction
Old 25-11-2005, 12:53 PM   #6 (permalink)
Also what is the best bitrate to encode,some videos are 2000 kbps,1700 kbps some are 800 kbps,which is the most reasonable bitrate.................................
Here's a good guide on using the "bits-per-pixel" method.
<Quote> As a rule of thumb, I usually calculate the "bits-per-pixel", that is you
calculate how many pixels are shown per second, e.g. for 640x480 at 25fps
it's 640*480*25 = 7680000 pixels per second. That you divide by the
bitrate. E.g. with 1000kbps, it's 1000000 bits per second, so you end up
with .13 bits per pixel which is a reasonable value.
Below 0.1 is often too low, above 0.2 is often not needed.
Many settings influence this, and the most important is the video
material that you try to encode.
E.g., if you have B-frames active, a somewhat lower number is acceptable
than without, and action material with explosions and fast motion etc.
should get more bits than e.g. a sitcom. <End Quote>
http://edu.bnhof.de/pipermail/xvid-d...ay/004262.html
Keith
Old 25-11-2005, 02:19 PM   #7 (permalink)
@Keith Sebastian
all these DVD players which come in the market which support divx...they support xvid too ???
that'l b cool
ishaan is offline
Old 25-11-2005, 03:42 PM   #8 (permalink)
Originally Posted by ishaan
@Keith Sebastian
that'l b cool
In India, all Philips and Mitashi's will support. Don't know aout the rest. Make a XVID disc and visit some home electronics showrooms.
Keith
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/19250-best-codec-bitrate-re-encoding-avi-files.html
doom9 ideal bitrate - Google Search This thread Refback 25-01-2011 01:09 AM
- by gforz
