well i have downloaded the 5 part file of solaris 10... all of them were zip archive containing a file inside without any extension....
now the info file says..
use a utility that understands the ZIP compression format to
unpack each file, use a utility that can verify a file's MD5 checksum to confirmeach file has been successfully downloaded, combine these files into a single file,
now i have extraced those each files... what software should i use to join them, as they dont have any extainsion so i dont have any clue... :roll: :roll:
