| Forum |
#1 (permalink) |
I've got a P II, and I've been using it for the last 6 years.... Recently I bought a new P IV so thought of cleaning up my P II and using it for some light weight use. I formatted my PC and re-installed the good old Windows 98. And then thought of installing the normal utils ..... installed Winamp 2.74 (didnt want to trouble my PII with the latest versions). But to my horror i un-installed winamp and tried playing it in Windows Media Player. But the problem still persists. But it works with the default media player (mplayer2) which comes with Win'98. 8) Btw, I've an Intel 810 motherboard, and ESS 1938 onboard soundcard. Kindly help my sweetheart PII get its voice back !!! Regards, Aditya |
#4 (permalink) |
No, dont do that, I use 9.0b on my old pc and it runs fine, just reinstall the soundcard drivers and see ... but the fact that mplayer works means it could be a fault in winamp ... get 3.0 or something from www.oldversion.com
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e |
#5 (permalink) |
Hi guys,
I havent removed DirectX 9 as yet. But Ujjwal, we cant blame Winamp coz even Windows Media Palyer doesn't work. Well the soundcard drivers are all installed well. The system doesnt show any conflicts in that respect. And mplayer working fine just gives a proof that the sound drivers are fine. I'm searching for any new version of ESS 1938 sound driver on the net. Suggest some sites if u know. Thanx, Aditya |
#6 (permalink) |
Have you tried www.driverguide.com ?
| Bookmarks |
| Display Modes | |
