Old 23-11-2005, 06:17 PM   #1 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default How to clear the tray history ? (Its too big !)
If we go to Start Menu (rightclick) > Properties > Taskbar (Tab) > Customize Button (Near Hide Inactive Buttons checkbox)
U can see a long list of tray programs..
How do u clear those programs that arent there anymore on ur comp ???
QwertyManiac is offline
Old 23-11-2005, 06:43 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
How to Clear Past Items from the Notification Area
http://support.microsoft.com/default...b;en-us;283084
or else use the latest version of 'ace utilities'. it does so.
www.acelogix.com.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 23-11-2005, 07:30 PM   #3 (permalink)
Commander in Chief
Thanks anandk,
problem solved, 3yrs's program memory cleared !
Thanks a lot....
- by gforz
