Old 23-11-2005, 12:19 PM   #1 (permalink)
Default deleting files permanantly?
is it possible to delete files permanantly from the hard disk
once it is written in hard drive it is said to be retriveable any how...
can i permanantly delete file from system using any software
or may be cery hard to retrieve even using any recovery software
is it possible
if yes
which software to dwonload
which is the best software in this...
i have to show demo to a client in php and delete files from thier computer after the demo .As php is open source i am not able to make exe file so i am confused what to do
want to delete file permanantly after demo show..
sad that i dont have laptop
can any body help
be who u r :
Saharika is offline
Old 23-11-2005, 12:33 PM   #2 (permalink)
siriusb's Avatar
Here's a simple software for deleting files:
http://www.snapfiles.com/get/simplefileshredder.html
To clean the (apparent)free space by zero-fill,
http://www.sysinternals.com/Utilities/SDelete.html
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 23-11-2005, 12:55 PM   #3 (permalink)
are you sure that it deletes files permnantly?
be who u r :
Saharika is offline
Old 23-11-2005, 01:38 PM   #4 (permalink)
alib_i's Avatar
I've used simplefileshredder .. it works quite well
Your files may show up in 'undelete' programs .. but they cant be recovered .. the file data is overwritten by random bytes ..
so it's quite safe that way !
alibi
-Metallica
alib_i is offline
Old 23-11-2005, 01:48 PM   #5 (permalink)
siriusb's Avatar
See the program description. But you will have to install this program to use it.
If u don't want to install any program, you can use the second link provided. Sdelete is a cmd promt app though.
siriusb is offline
Old 23-11-2005, 04:31 PM   #6 (permalink)
ican isntall soft
the main thing is that the file delete should not be recoverable
even after 1 hour or delete...
i have downloaded that soft
is it possible from there
thanks for all replies...
be who u r :
Saharika is offline
Old 23-11-2005, 07:17 PM   #7 (permalink)
there is also one called CUTE FILE SHREDDER
and i got a tip for you...if u have to do this kinda stuff often...it will be useful for u 2 invest in a small pen drive...so u can keep ur files on it n show d demo from d pen drive only
ishaan is offline
Old 24-11-2005, 02:23 AM   #8 (permalink)
Learner
Kniwor's Avatar
u can use....eraser...
after u install it will add an option erase to the context menu... now just erase the file u want to...
the key is overwriting... if u overwrite 3-4 times(with random data) it will become almost ompossible to recover...
there will be an option in eraser to specify how many times to overwrite.... just say 4.... and relax...
Kniwor is offline
- by gforz
