Old 11-10-2004, 02:57 PM   #1 (permalink)
tweety_bird_bunny's Avatar
Default ''will rock'' not willing to play!!!!
hi...
i bought CD of will rock...
it installed perfectly.... but as i clicked on its icon, it shows a error..
" gsvideoinit() failed '' .... how can i correct this?????
tweety_bird_bunny is offline
Old 11-10-2004, 07:15 PM   #2 (permalink)
GameAddict's Avatar
Default May be this link can answer your question....
http://www.techimo.com/forum/archive.../t-114854.html
GameAddict is offline
Old 11-10-2004, 09:45 PM   #3 (permalink)
Default videoinit() failure
You have bought a cracked CD. You have to replace the original EXE file with the cracked version. Also check whether your graphics card is supported by the game
sweetvenom is offline
Old 11-10-2004, 10:01 PM   #4 (permalink)
the ripped game dont work here either.
sniper is offline
Old 12-10-2004, 01:43 AM   #5 (permalink)
ice
Whats will rock?
ice
ice is offline
Old 12-10-2004, 09:48 AM   #7 (permalink)
Hey tat error sounds like a video problem.Try updating ur video drivers.
Tat should work .
If it dosent reply back with ur system specs.
beyondthegracefgod is offline
Old 12-10-2004, 01:35 PM   #8 (permalink)
swatkat's Avatar
update directx to 9.0c,update ur graphics driver and then try.close all other applications while playing.
http://swatrant.blogspot.com/
swatkat is offline
- by gforz
