Old 21-11-2005, 11:39 PM   #1 (permalink)
lahratla's Avatar
Default Couldn't use Avast 4.6 Home Edition
I'm using Avast v4.6 Home Edition in Windows XP+SP2. The On-Access Protection has been turned of by itself since some days back and I can't activate the On-Access or launch the Anti-Virus. Manual Scanning is also not possible.
Repair, changing or reinstalling did not help.
1. When running the Quick Scanner, an error message saying [Program cannot create "Object" in "Storage"] appears.
2. And when trying to start the anti-virus, the following error messages appear consecutively:
"Unkown Error. Configuration is not loaded properly. Err: dbsCreateObject"
"Unkown Error. Program cannot save parameters to the storage! (Error: dbsCreateObject)"
3. And when trying to start the On-Access Protection, the following error message appears:
"avast!: The AAVM subsystem detected a RPC error. The opeartion could not be completed."
Please help.
lahratla is offline
Old 23-11-2005, 08:01 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
uninstall avast.
search for and delete all 'avast' files/folders, physically.
reboot.
download and use 'ccleaner' from www.ccleaner.com to clear pc junk.
reboot.
do a fresh avast instal.
it shud solve ur problem.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 23-11-2005, 09:40 PM   #3 (permalink)
selva1966's Avatar
If that does not solve your problem download avast uninstaller from thier website which is around 212 KB save it in avast folder and uninstall completely.
Then reinstall and report.
selva1966 is offline
Old 23-11-2005, 10:50 PM   #4 (permalink)
lahratla's Avatar
Default No help yet
lahratla is offline
- by gforz
