Old 21-11-2005, 09:46 PM   #1 (permalink)
Default Can I do this..
Can I run Windows XP 64bit on a 32bit machine??
If Yes.. then what effects will i have.
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 21-11-2005, 09:51 PM   #2 (permalink)
no, i dont think it is in anyway possible without the hardware upgrade
Shwetanshu Srivastava
shwetanshu is offline
Old 21-11-2005, 11:06 PM   #3 (permalink)
Learner
Kniwor's Avatar
No u cannot do this......
u cannot directly install it anyways...
the only hope u have is simulators which there are none out by now...reson....No use.. it will be slower if 1 makes one....and XP 64 is already with poor driver support too...
so u get my point....
BUT..........why the hell do u want to run XP64 on a 32 machine... slower, no drivers etc.... I see not reason for doing this except for purely experimental
Kniwor is offline
Old 22-11-2005, 09:23 AM   #4 (permalink)
I was just curious to know... nothing else..
www.digizeal.org
Come and check
- by gforz
