Old 11-10-2004, 10:12 AM   #1 (permalink)
Default compression querry
I have a lot of data on my pc that i dont use (dumped data)
Whcih is the best compression method so that it occupies less space I mean zip it or any other tecnique in more effective
Same is the case with my video files so which is the best format 4 videeos which occupies less space plz recommend the sofware 4 the purpose 2
Thanx in advance
Never argue with an idiot ,first he will lower u till his level ,then beat u with his experience.
akitosforever is offline
Old 11-10-2004, 10:32 AM   #2 (permalink)
The Photoshop Guy
cooljeba's Avatar
hmm
for compressing the data u can rar it..... with best compression but it gonna take a lot of time!!
regarding the video compression divx ofers the best compression!!!
try this thread it will help u a lot
http://www.thinkdigit.com/forum/viewtopic.php?t=6925
..:: peace ::..
Jeba
cooljeba is offline
Old 11-10-2004, 01:57 PM   #3 (permalink)
If you have lots of free RAM, then you may try out 7-zip http://www.7-zip.org/
It offers MUCH better compression that any format, but downside is that its slow and uses a lot of ram (while compressing and decompressing). Of course, you can configure it as to how much compression you need, so its a question of speed/ram v/s size.
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
- by gforz
