Old 21-11-2005, 08:39 AM   #1 (permalink)
Default Problem with swf file
can anybody tell me how to run SWF files? I have installed shockwave and flash player though. by the way I have got the file from my temporary internet files. Can I run the file when i m offline? If yes then how?
tanmoy_rajguru2005 is offline
Old 21-11-2005, 10:37 AM   #2 (permalink)
try running em in IE or mozilla firefox
make sure u got the latest flash installed
ishaan is offline
Old 21-11-2005, 10:56 AM   #3 (permalink)
go for ishaan, if u install macromedia flash player, u can run .swf files directly i.e w/o ie or FF.
It is free to use. use google for finding the download link.
ashnik is offline
Old 21-11-2005, 07:42 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
The BEST way is what ishaan told!
Open the swf file in either IE or Firefox.
One other way is install K-Lite Codec Pack thn u'll be able to play the file using Media Player Classic also
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 22-11-2005, 12:32 AM   #5 (permalink)
Thank u all. It solved the problem.
- by gforz
