Old 11-10-2004, 07:55 AM   #1 (permalink)
Default Porting html to aspx
Hi guys,
I have done a prototype for a web application in html. Can you guys tell me the method/procedure/standards I should use to port the html coding to aspx ?
I will be using C# as code behind.
Thanks
a wise man once said:
\"he who laughs last.........doesn\'t get the joke\".
shehan9999 is offline
Old 11-10-2004, 09:28 AM   #2 (permalink)
The Photoshop Guy
cooljeba's Avatar
post it in qna section m8
..:: peace ::..
Jeba
cooljeba is offline
Old 11-10-2004, 09:46 AM   #3 (permalink)
Hi Shehan,
HTML to .aspx porting is not possible, you have to develop your web application as an ASP.net project, where there is an option to select C# or VB.net as the code behind language. for this you must have the knowledge of ASP.net technology as well as C#
Regards,
Kshitij
India Developer Network
www.indiadevnet.com
The Indian Software Developers Community Online
vbtech is offline
- by gforz
