Old 18-11-2005, 06:38 PM   #1 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
Default need for shutdown .....??
can anyone tell me why do we need down
i know about data loss and crap but given tht we all r geeks here
is there any kind of hardware damage when we shut the power of directly
if so can u priciesly tell wat the damage is ....???
vijay_7287 is offline
Old 19-11-2005, 01:21 AM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Yes .. Your harddisk have a number of platters on which your data is written .. To read and write data from these platters, the hard disk have heads ... These heads are in continous radial motion and platters in rotation .. When you give a proper shut down command, the head goes back to Track 0 but if you shut it down abruptly, the head will remain at the position it was .. And when you power it on, it will start from there only .. Which have a greater proximity of head damagin the platter ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 19-11-2005, 02:22 AM   #3 (permalink)
siriusb's Avatar
I don't think the problem of head parking is with us today. All of the disks that's been around for the last few years have a mechanism of storing enough power to safely move the head to the landing zone even in the event of a power cut. But I think it doesnt work all the time, as I keep hearing of physical damage due to abrupt shutdowns.
Metal fatigue due to cooling and heating can be a method of damage. But you've got about a million shutdowns before that becomes a problem.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 19-11-2005, 05:56 PM   #4 (permalink)
i think a shutdown also helps in clearing all the virtual mem, the RAM and all that stuff
not sure tho
plus, wen u install some softwares, they need 2 install some files without windows running so ur required 2 do a restart
and u mite have noticed sometimes u try 2 delete something it sez u cant cuz its in use even tho it isnt...thats cuz windows is sumhow using it...so after a restart u can delete it...
stuff like that
ishaan is offline
- by gforz
- by soumya
